Error When Batch Plotting
Whenever I select the batch plot command, I get the "Microstation Text Window" and the program essentially crashes. Any ideas as to what I could do to fix this?
Thanks...
RE: Error When Batch Plotting
Check the configuration of your workspace, it is probably not set properly.
