Valve for water, sand, and gas mixture
What is the most cost effective 2” isolation valve for a drain?
Fluid: water / sand / gas mix.
Pressure: 2220 psi
There will be a globe valve upstream of the isolation valve that will be shut in first so the problem of the fluid cutting the seat of the isolation will be minimized.
Pressure: 2220 psi
RE: Valve for water, sand, and gas mixture
I would recommend a plug valve for mixture with sand. One manufacturer would be Nordstom with valves up ANSI CL2500 and API 5000. There may be others at lower cost.
