Heat Treatment Requirment for PV
May you please advise whether there is ASME VIII Div. 1 requirement for heat treatment of -50 ºF (or lower) design temp. vessel?
Thank you very much in advance.
RE: Heat Treatment Requirment for PV
Could you please provide more background information related to your question?
The -50°F issue is more related to material selection than to PWHT. PWHT will be resulting from the material choice and service conditions.
Code PWHT is generally based on thickness. If you perform Non-Code PWHT it is possible to reduce your MDMT by an addition 30 degrees F (see UCS-66(c)). Lets say you build a vessel that doesn't require Code PWHT and you have impact test excemption down to -20F. Your client now want -50F. You perform PWHT and you get -50F without impact testing.
Sorry, thats UCS-68(c)
I knew I was missing something, codeeng.
That requirement is only good for P1 materials.
And I still don't know what the original question was...
