Tapered Beam Elements
I am trying to create a tapered beam element and keep receiving an error stating 'SKIPPING SHEAR AREAS AT SECOND END OF BEAM PROPERTY 1'. I tried changing the taper ratio to see if I violated a parameter with no luck. Thanks in advance for any help.
