Removing hub and bearing from shaft
Gents
I am about to replace stuffed spherical roller bearings on a pinion shaft which goes hub - bearing - integral gear - bearing.
The shaft is about 14" diameter, hub is keyed and bearing is press/shrink fit. Hub is about 17" long
Planned procedure is:
Heat hub to around 100 deg C with gas and remove using strongback and 25T hydraulic ram.
Gas cut off bearings.
Dress shaft if required.
Induction heat and fit new bearings
Heat and refit hub.
Time is the enemy.
Any recommendations so speed things up or reduce the risk of problems?
Steve
Heat and refit hub.
Time is the enemy.
Steve
RE: Removing hub and bearing from shaft
Lester Milton
Telford, Shropshire, UK
