ANSI Class 6 standard origins?
Hello everyone,
On a recent search for PVC butterfly valves, I noticed that most companies refer to ANSI Class 6 shut-off as criteria for valve quality. I need to know what ANSI Class 6 shut-off means, and how the valve is built/tested to meet this criteria. What standard does the ANSI Class 6 classification originate? I looked on the ANSI site, and throughout the web, but can't seem to find it. Anybody have a clear definition of ANSI Class 6, and a source to refer to?
RE: ANSI Class 6 standard origins?
Class I requires no testing while Class VI requires that leakage throught the valve don“t exceed certain amounts depending of the size of the valve, Test is made with air or nitrogen and a differential pressure across the valve of 50 psig or max rated pressure wichever is lower.
John
Please take also a look, within this Forum, at:
- Thread408-23297;
- Thread408-45258;
- Thread174-76111 and Thread408-76110.
Hope this helps, 'NGL
