importation of ".igs" file for meshing
i'm using SolidWorks as modeler, but i want to mesh my parts in I-deas. So i create ".igs" file. when i import them in I-deas, that's all right still i try to mesh in solid. i can select the solid part, make the external mesh (like a skin mesh)but then it says that it can't save my mesh because it failed...and that's all i have!...
Have you any ideas?
thanks a lot for your help
ldd
Have you any ideas?
ldd
RE: importation of ".igs" file for meshing
Are you sure your mesh isn't failing due to small features or something related to the geometry? If you have difficult geometry the mesh can fail unless you specify a smaller mesh or control the free locals when volume meshing and controlling the curve points when section meshing. Please elaborate.
