Excel Macro Format Problem
I have the following in a macro:
    For i = 1 To endRow
        PN = ActiveCell.Value
        EC1 = ActiveCell.Offset(0, 1).Value
        If EC1 = "" Then GoTo Next_PN
        For j = 3 To Worksheets.Count
            Sheets(j).Activate
            Range("B4").Activate
            ACV = ActiveCell.Value
            If ACV = PN Then
               ActiveCell.Offset(0, 16).Value = EC1
My If check never finds a match because PN=1234 and ACV="1234".  Originally PN was formatted general and ACV as text.  I reformatted ACV as general but I still don't get a match. How do I fix this?
RE: Excel Macro Format Problem
Instead of = try Like
Hope this helps.
maybe only a drafter
but the best user at this company!
That worked perfectly.  Thanks.
fyi...
it appears that the vba code sees PN as a number and ACV as text, regardless of formatted type. while the "like" comparason may suffice the needs, the cell function =value(B4) converts text to a numeric value. hence, the comparason can be made with like data (i.e. comparing numbers).
good luck!
-pmover
That would be best but each of 7 suppliers has 20+ part numbers each on their own worksheet.  I have the files shared for multiple users and I don't fancy missing the season premier of Smallville tonight to do it when no one is around.
Apparently the guy who started these files formatted everything in the top x lines as text.  Had he left them as general I think everything would have worked.
