Photoworks Render Manager Problem
Is there a way to remove all photoworks information from a file after it has been rendered. Whenever I click on the Render Manager Tab SW closes and gives me an unhandled error message. It only does it with one file and works normally with all others. This is SW 2005 SP0 on Win XP SP2.
RE: Photoworks Render Manager Problem
XP SP2 isn't support I hope you know that. SW may work on it?? but SW recommends that you don't update until SP1.0 of SW05 or SP5.0 of SW04
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
I do know it's not supported but we've had it running on several machines in the office with no problems so I decided to give it a try. What's really strange is that it is only affecting one particular assembly that I have never had a problem with until now.
To remove a photoworks material simply click on the photoworks tab and click and expand the Materials folder. Highlight the material(s) and click the delete key.
Do this for scenes etc...
Scott Baugh, CSWP
That is exactly what I can't do. When I click on the photoworks tab (render manage) in the maager block, it kicks me out of SW giving me the unhandled error. All other functionality (that I use) is normal. I need to remove all rendering completely as if it were never rendered and then try to create the rendering again, if that's possible.
Just a Thought.....
A man should look for what is, and not for what he thinks should be. -Albert Einstein
A person who never made a mistake never tried anything new. -Albert Einstein
Try opening it up on another machine. This will help rule out it being your machine of the file.
Scott Baugh, CSWP
I just opened it on another computer and had the same result.
Any other thoughts on removing the rendering info from the file?
Scott Baugh, CSWP
