Class A: Alias/ICEm settings vs. real outcome
Wondering whether surface analysis (coloured grading of curvature) in Alias and ICEM correspond to real outcome in tooling?
Recomended settings vs. milling/polishing tolerance?
Are we being to concious about virtual curvature? (A lot of work can be saved here...)
If coated, does paint add or smoothen uneveness?
/Gilea
RE: Class A: Alias/ICEm settings vs. real outcome
What manufacturing process are you talking about? That is everything.
Hi HDS,
I basically have an interest in 3 of them: steel sheet forming, alu sheet forming and injection moulded,  all coated. A detail such as a front fender could work as an example.
Still, a connection between more methods (inj mould patterned vs. glossy, RIM, and even textiles) and achieved accuracy would help a lot in our daily work.(soft chairs are often modelled today with even surfaces for some reason)
/Gilea
In automotive work the areas affected by changes in curvature can be large and are hard to fix by polishing.  If it is a small area it can be done but a fender is probably too big. Painting will usually make the part shinier and the problems bigger. Texture can hide your problems if it is deep enough and the plastic dull enough.
I know what you really want is the numbers to look for but I don’t have any to give you.
Hi again,
thank you for the info.
The reason for raising this question is that we made a comparison with a voxel modeller (Freeform) which can export in NURBS-based surfaces, which were analyzed in Alias. Time spent in voxel modelling i one third compared to surfacing...
The same geometry was made in Alias and compared. Using "zebra stripes" analysis, no difference was detected!
However, when colored fields were applied a difference was detected in favor of the Alias surfaces. So, is "zebra stripes" accurate enough?
/Gilea
