Load Loss Calculation Formula
Can anyone refresh my memory and tell me the valves (psi) and pipe load loss calculation formula
RE: Load Loss Calculation Formula
friction rate, flow velocity, 2g and so ...
I hope I be clear this time
Hopefully my website + the link page can help you further.
www.carf-engineering.com
CARF
Thank you so much for the soft, but.
Do I can use to calculate head loss from start point to a flare, for example, in a gas piping system? I'm awaiting your reply asap.
TX IN ADVANCE.
I dont know what this is for - but if ts for a real system then i think you should be more carefully in your work. While a internet page might help you "refresh" your mind a little you questions seems very basic and design of PSV's and flare system is VERY important stuff both from a safety and from an operational point of view.
How will you document this? You should see more professional help (inhouse or from an external consultant).
Best regards
Morten
Cheers,
CARF
