Preparing new pipes for service
I have some small carbon steel pipes (1 inch) that have been sitting open to the weather for about a year. I now want to finish the piping run and use them for clean solvent transfer. The problem is that the existing piping is now rusted on inside near the welded areas. How would you go about cleaning the pipes and commissioning them? Shot peen the pipe? Pump an abraisive slurry through them? Throw them out an get new pipe? Could you acid wash them to remove the rust?
StoneCold
StoneCold
RE: Preparing new pipes for service
The piping is not used, it was just never commisioned. You know, typical dead project that is now being resurected.
proceed with fabrication of the piping system and include connections/fittings for conducting a mild citric acid cleaning of entire system. there are firms that specialize in cleaning of piping systems &/or equipment and these firms should also be responsible for disposal of cleaning solution and any debris removed from piping system.
might want to compare cleaning costs with costs of new pipe/fittings.
good luck!
-pmover
I agree with pmover. Acid cleaning is probably the way to go if anything (assuming that the system is assembled with the rusty pipe - if you can send the pipe out to get cleaned & returned, then maybe you have more options). When you commission a boiler you would do an acid cleaning to remove mill scale. I think it would also take care of rust. It generally involves citric acid, a pump and a small boiler to heat the solution up a little. The key to the above comment is getting the cleaning company to take care of disposal. Chances are your waste treatment system isn't set up for it.
Jay165 I only have about 120ft of pipe so I don't think Haliburton is interested in my problem.
Pmover and Gmorin I am going to try the citric acid bath in the lab. If that works I will probably do it on the pipe in the field after it is all assembled. I am at a chemical company so we can deal with the waste workup.
If it seems very difficult we will just install new pipe. However even new pipe cah be rusty and this might be a great way to commision the piping system. Acid wash then rinse with water then dry with solvent and N2.
Thanks guys.
StoneCold
TTFN
citric acid may be working also, though I would presume this will take longer than HCl. With concentrations in this range, you have corrosion of 2 to 20 mm per annum, so you don't have to fear any substancial loss of wall thickness. The typical duration until clean would be about 8 hours of circulation.
Keep in mind to absolutely exclude dead ends, as the acid will probably sit in there. When you dry out with dry air, the acid in the dead ends will be partly evaporated and kill the passivation. It will also promote a new layer of rust very fast.
I just had about two weeks of fun on exactly this topic. You need to observe the pickling very closely.
hth,
chris
We never used them to remove rust (we were an OEM and our boilers were installed/commissioned soon after fabrication), but it is definately worth a try, esp. if you can do a test in your lab.
good luck.
Check with Praxair's sandjet technology. Uses nitrogen and sand. Leaves a bright metal surface which can be followed by a epoxy liner....
