Rendering in Microstation
I have a pretty complex model of my building. When I set up a camera and target script to rotate around a room, that works fine. My problem is when I go to do the rendering. I have applied a transparent material to a couple of the walls to show important items behind them. When I do a still shot, or render it is transparent and just fine. But when I hit the record a script command and send it out to jpg files. It sets the walls to a solid, and is no longer transparent. Has anybody come across this, and may know of a solution.
Thanks in advance.
Adam R. Fuller
Senior Drafter
Thanks in advance.
Adam R. Fuller
Senior Drafter
