Part modeling - how do I create a bent ribbon cable?
What is the best way to model a ribbon cable which bends a couple of times back upon itself?  Imagine folding a ribbon cable so that it travels perpendicular to it's origin, and then folding it perpendicular to itself again so that it is now traveling parallel to its original path.
I just can't get a smooth model.
Air cooled, belt fed, gas operated machine gun firing from the open-bolt position
RE: Part modeling - how do I create a bent ribbon cable?
m60gunner,
I would use sweep.
Bradley
If I were you I would create a 3D sketch of the cable profile that you want, keeping in mind that you can not have it intersect with itself but you can make it look close to folding onto itself. Then create a sketch of a circle on a plane that is normal to the curve at one end. This sketch should represent your cable O.D. Next sweep the profile so that now you have one wire of your ribbon cable, then do a linear repeat in any direction offsetting your profile width. Now if you need to edit the cable you just have to modify the 3D sketch accordingly and the rest should follow.
Hope this has helped you.
The problem I get into is that it's almost like a sheet metal feature - the ribbon cable gets folded 90 degrees but creates a 45 degree fold line to make the cable route perpendicular to its original path, then it does it again.
Sweeping a single cable/wire/circular profile would work for a wire, but how do I make it work for a flat ribbon?
If I understand, you can draw a rectangle instead of a circle.
Bradley
forgive me if I am wrong but isn't a ribbon cable just a bunch of round wires molded togeter.
I still think that you can create this using a sweep and then a linear pattern. 3D sketch may not be what your looking for but if you create your profile correctly sweep will work for this application.
To create the 45 degree bend you could create your ribbon wire as discussed above using a linear pattern. then cut the wire on a 45 degree then open a sketch on the cut face. Convert entities. Then create a sweep path to fold over itself.
I hope I explained that enough.
If you would like I have a solidworks model showing what I am trying to explain to you. Give me your email and I will send it to you.
Draw the circles attached together in a sketch. Draw a 3Dsketch and 3Dsketch guide curve. Sweep it along the 3Dsketch and the guide curve.
m60gunner
Your second post hit the nail on the head. Unless you need the fine detail of the wire ribs, the simplest way is to use a Sheet Metal part. A thread texture can be used to simulate the ribbed appearance (sort of) & the part file size will probably be a lot smaller. Also you will be able to flatten the cable should you need to.
Sure it can be done using Sweep but Sheet Metal will be a lot more practical & quicker.
from (the City of) Barrie, Ontario.
What happens if you get scared half to death twice?
I don't belive you can show textures at the drawing level if you needed to show a drawing of the cable. Otherwise you need to use the method I have discussed.
I really appreciate the input.  "ctopher", I am not familiar at all with 3D guide curves, but I am working on that approach.
"CorBlimeyLimey", the sheet metal option seems to be the route that I will have to take.
I saw your file, Scott, and that's the extent to which I can do the sweep.  Try making a 90 degree turn with it now.  That's the problem.
I don't need the circular shape to show up in a detail drawing. Textures will work for me in the assembly.  A totally flat plate will do.  It just has to fold over to turn 90 degrees twice - just like a sheet of paper...fold one end so that is now at a 90 degree angle from the opposite end... now there will be a 45 degree fold
jksolid
m60gunner was not asking about drawings, but you are correct ... you cannot show textures in drawings. Hopefully we will be able to in some future release.
BTW ... the method you describe will not sweep a true profile of the ribbon. If cut at 45° the wire section will become eliptical & the ribbon width will be "stretched". Probably good enough for what's needed though.
Actually I tried to do a true sweep of a folded ribbon & gave up after 1/2 hour. Made the same thing in Sheet Metal in less than 2 minutes!!
CorBlimeyLimey, can you send me what you came up with?
m60
You should receive it any time now.
Thanks all for the input.  It seemed like an easy task, but I couldn't think of the best way to tackle it.
It is definitely a sweet assembly model and the drawings are looking good, too!
Thanks again!
An added note.  If you do end up wanting to represent the individual wires on a drawing, apply a hatch to the area.  Use something like steel.  Rotate and scale the pattern until it looks like a bunch of grooves.
If anyone is able to model this folded ribbon using a sweep, I would really like to see it. My email address is CorBlimeyLimey AT lycos.com
I guess I don't follow what your trying to do exactly. It doesn't matter if it's SM or a sweep. You can't have it pass within itself.
m60 said:
Which direction? I updated it so the ribbon doesn't pass within itself. See http://www.scottjbaugh.com/Design_Portfolio/SW%20M...
Scott Baugh, CSWP
http://www.3dvisiontech.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
It is a little difficult to explain verbally...
Take a flat ribbon, lay it on your desk.  Now take one end and fold it so that it is running perpendicular to the end that is still laying flat.  Do not bend it up or down - bend it left or right.  Kinda like dog-eared pages - folding the corner of a page down will give you the same bend that I am trying to.
Truncated URL, file not found.
"But what... is it good for?"
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Sort of, but the cable doesn't stretch around the turn like you are showing it, it gets folded such that the outer wire (last) in the ribbon is the same length as the inner wire (1st) of the ribbon.
SM stretches the metal when it's bent. How can you say that SM isn't streching? I understand what you mean with a ribbon not stretching around a corner but the SM would do the same thing.
Scott Baugh, CSWP
I agree - but SM would not give such an exaggerated stretch - it wouldn't be visibly noticeable.
CorBlimeyLimey just sent me the SM file. I'll work on a Sweep form of this. Just for the challenge. I'll post here when I finish it.
Thanks!
Scott Baugh, CSWP
Can't wait!
I use sheet metal starting with a flat sheet and adding sketched bends at 180deg, sketched at 45 degree angles.
I used both the sweep and the sheet metal - different configs.  I actually needed the appearance of the individual conductors at one point, so the sweep worked well in that case.
Some good ribbon cables out there!
Does anyone use Router? I'm curiuos if it does ribbon cables.
Is the cable detail really needed?  If not has anyone considered a surface sweep and thicken?
Christopher Zona
Litens Automotive Partnership
Concord, Ontario, Canada
