Unable to find an appropriate resource dll
I get the error in the subject at the beginning of SW2005 SP0 installation. Does anyone know a way to solve this problem?
Thanks.
Thanks.
RE: Unable to find an appropriate resource dll
That isn't really enough information to tell you waht the problem is, but if I had to take a guess it's a problem with your OS.
What OS are you using?
What SP of the OS are you using?
When installing you should also get some type of code. That code can be looked up at microsofts site - Located in this FAQ559-520 - under Tips and tricks second from the bottom.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
What is the name of the dll file?
Bradley
