Drawing from sketch?
From time to time I want export a specific sketch as a standalone drawing, with measures and so on. The problem is however that measures semm to disappear when simply copying the sketch into a drawing, and I can't change the scale.
Anyone has a smooth solution for making drawings from sketches? I've probably missed something obvious, at least I hope so.
Thanks! :)
Thanks! :)
RE: Drawing from sketch?
I assume you are starting a new part, then creating a sketch in that part file, then trying to drag and drop this sketch into a new drawing.
It's easier to open a new drawing and start sketching right in the drawing. You can add relations, dimensions, center lines etc, as you go along.
This should work perfectly fine for simple 2D drawings where, for example, a simple end profile and length note shows everything you need to know about the part.
Best Regards
Adrian Dunevein
AAA Drafting Services
www.aaadrafting.com
Or you can do it like Adrian2 suggested. Just start your sketches and add Dimensions inside of a new drawing.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
