Alternative to baffles to attenuate storm manhole damage?
Howdy,
I have to design a series of 4ft diameter storm manholes along a road with a 65 ft elevation difference (from end to end) and the municipality has insisted on:
1. no more than 6 feet of drop per manhole
2. minimize maintenance due to erosion caused by the high expected flow velocities (approx 12ft/s)
3. NO baffles allowed
In order to reduce the erosion due to the flow slamming into the opposite wall of the manhole I am thinking of a way to produce a drop at the end of the incoming pipe to "guide" the flow straight down. Doing this in the pipe sounds like a pain....perhaps there is a way to accomplish this by modifying the manhole barrel just below the invert of the inlet...perhaps a "ramp" of some kind?
Any suggestions???
Thank you in advance for your help!
Shane in Canada
Any suggestions???
Shane in Canada
RE: Alternative to baffles to attenuate storm manhole damage?
Best Tincan
