Dimensions change to dangling
I have a user here that dreated a dwg today. The problem is he created a section view, dimensioned it, looks good. Now after he moves or re-sizes the view border, all of the dimensions turn to dangling dimensions. Has anyone seen this before? We have SW04 4.1.
RE: Dimensions change to dangling
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
If the section line is not tied down, I've seen them shift slightly in the past. This shift would redefine the cutting plane, therefore redefining the cut edges.
John
