Instrument or DCS signal filter
Should an analog signal be filtered in the instrument itself, if available, or shoud we have the DCS/PLC filter the incoming signal.
For example, many instruments will allow a first order filter on the output of the 4-20mA signal.
Our DCS will allow us to do the same thing with the incoming signal. I don't want both doing the same thing, so which one is the better location?
It makes sense to have it all in the same location: either all in the various instruments or all in the DCS, but I'm sure not all instruments will offer this option.
Which is better?
Any suggestions?
Which is better?
Any suggestions?
RE: Instrument or DCS signal filter
