Data conversion
Data conversion
I have a pkg file and when I try File->Import->IDEAS Library Data, select the pkg file, and then it display the warning Data conversion requiered.
any ideas
any ideas
RE: Data conversion
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: Data conversion
When you hit OK a Command Prompt window should open which then converts the data and asks you to import it a second time. This time it will bring it into the TDM
If anything different from this is happening then reply back.
