Anyone have acces to NACA-TN-1830 or NACA-TN-1974?
I have been researching the effect of stress concentrations on the ultimate strength of a cross section and I have not been able to find an electronic copy of the following documents.
NACA-TN-1830 "Tension properties of aluminium alloys in the prescence of stress raisers"
and
NACA-TN-1974 "Effect of open circular holes on tensile strength and elongation of sheet specimens of some aluminium alloys"
They are not available from the NACA technical report server.
Is there another URL to use?
FYI my current understanding is:
The effect of stress concentrations varies depending on material ductility in two ways (1) ductile materials show strengthing as plastic flow eliminates the initial stress concentration (2) non ductile materials show weakening due to non uniform stresses and strains at the notched region. (Ref NACA-TN-2433 Page 10). Thus you need to know if your material is strengthed or weakended by notches when considering failure.
Thanks in advance.
and
Thanks in advance.
RE: Anyone have acces to NACA-TN-1830 or NACA-TN-1974?
Steven Fahey, CET
"Simplicate, and add more lightness" - Bill Stout
Let me know if they help.
Russ Royal, Aeromec Inc.
http://naca.central.cranfield.ac.uk/
Where you can find all the archives from NACA.
