adding a title block
hi all,
having trouble adding a customer title block to my drawing... what is the correct method?
thanks
thanks
RE: adding a title block
File - Import - Part
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
www.dl-engineering.com
We were using patterns. They appeared in the part correctly and seemed to work well ... except that when the part was next retreived by someone they didn't see the title block pattern. It was still there. In fact, it could be replaced with the same pattern.
Finally we quit using the pattern. Perhaps that was not the best choice. Have you any ideas why the pattern was not visible?
Adding Formats has always been an ideal area to automate. By programming the pattern additions, matching attributes can be set at the same time, synchronized with master-models, as well as a host of other standard checks and balances.
-MikeN
SolidNX.com
I missed setting that environment variable.
