filters blocking - recycled glass / fine agregate
Local Authority is recycling glass through a hammer mill, glass bottles, etc, stored outside (wet), the hammers are wearing out fairly rapidly, (8 hrs operation), the council are looking into the hammer tip problem. My query is that the end product is vibrated over a steel plate with approx 6mm dia holes, the combination of the glass shards coming out of the hammer mill & the moisture content of the fines is blocking the top plate holes & channelling all material (< 1mm) into the 'oversize' catchment bin.
IN A NUTSHELL HOW DO YOU KEEP THE TOP PLATE (& THE LOWER PLATES) FILTER HOLES FREE???????? I know one of you will have an viable answer - giv us a solution
shipleyttg@supanet.com
RE: filters blocking - recycled glass / fine agregate
ChemE, M.E. EIT
"The only constant in life is change." -Bruce Lee
