Procedure for handling Potassium Permanganate
We will be using Potassium Permanganate for our scrubber. Any suggestions in handling this chemical as it is hazardous and safety to personnel is very sensitive for this.
RE: Procedure for handling Potassium Permanganate
material data safety sheets are the best source
if you employer does not have them, then the supplier of the chemical or the internet is a good source
Thanks. I have it already from the internet.
The greater hazard is likely the material after it absorbed the H2S, etc.
John
gladken, Check the following website:
www.caruschem.com
They're the worlds largest manufacturer of Potassium Permanganate.
Hope this helps.
saxon
I've got another question!
Is KMnO4 solution reacts with BI pipe?
