adding 3d roller bearing to shaft
pls help me.
adding 3d roller bearing to shaft is not possible for me
RE: adding 3d roller bearing to shaft
I could not understand why it is not possible for you. Adding 3D bearing to a shaft especially if you know the bearing code (i.e. 6202), you just select the bearing location on the shaft; then select the bearing from the supplied list and then insert using aminsert.
Drkwing
