Movement Joints in Interior Concrete Masonry Walls
What is the maximum recommended vertical joint spacing for interior concrete masonry walls? Is there a difference if the walls are interior or exterior? (I'd think you could get away with a larger dim spacing on interior walls, since it doesn't go thru the thermal expansion and contraction that an exterior wall gets)
RE: Movement Joints in Interior Concrete Masonry Walls
best, Tincan.
