Dry to wet basis
Dry to wet basis
Dry to wet basis
Hello
I am doing energy balances to cracking furnaces.
I have the %vol O2 at dry basis and I want to convert it to wet basis.
What is the best way to do it?
Thank you
AndreChE
RE: Dry to wet basis
AndreChe,
Do you know that dry flow or the wet flow rate as a total? If it's dry flow and you also know volume of water vapour then it's easy just recalc the % by determining dry volume flow and dividing by new humid flow rate.
If it's a wet flow then you need to calculate the volumetric ratio for your stream which can be done from knowing pressure, T and humidity ratio, or if you know water vapour volume flow.  You can directly correlate the dry flow rate from this data and using this recalc your %O2 as a wet basis.
I don't know any other way that's easier I'm afraid.  I have a thermal balance calculation spreadsheet that I use for enthalpy calculations in my absorption column calculations if you have traouble I can copy the relevant section of the calcs and send through to you by email, let me know how you go.
Cheers,
K.
AndreChE:
To convert the concentration of a gas component from a dry basis to a wet basis, you must first know the water vapor content of the total gas:
wet basis concentration = (dry basis concentration)(1 - w)
where:
wet basis concentration = volume %, volume fraction, or ppm by volume
dry basis concentration = volume %, volume fraction, or ppm by volume
w = volume fraction of water vapor in the total gas
Milton Beychok
mbeychok@xxx.net (replace xxx with cox)
(Visit me at www.air-dispersion.com)
