SolidWorks/PhotoWorks Colour & Texture
I would like to know whether the texture or colour which show in SolidWorks & Photoworks are match with the standard colour code like "Pantone code"? If not can anyone suggest a method to check the colour code?
Pls advise.
Thank you.
RE: SolidWorks/PhotoWorks Colour & Texture
I don't follow what your talking about?
Need more information?
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
I don't beleieve they match unless you were to create your materials using the specific Pantone color formula.
no its a standard rgb or cmyk value colour table
there is something on the web which gives the rgb or cmyk values to establish pantone colours for photoshop users i suppose you could use that
kind of like a cross reference chart
Thanks guys, especially G1Design. I think the SWX color definition is based on Windows Color tools, which is RGB based. G1Design, can u recommend any website for me?
Here is a way to deal with this (it's OK for me!):
Try to find a digital sample of Pantone or RAL color codes (search the internet). Or scan a color chart in a quality scanner.
Use a color picker software (you can search for freeware on the internet) to find the RGB code that best match the "digital" Pantone/RAL you need.
Input the code in SW.
Of course the result is not the exact color code, but it's good enough to represent the real thing.
