Deflection calculator
I am a home designer. Is there such an animal as a deflection calculator that will determine the design deflection of a specific steel beam section given known spans and loadings? I have access to span tables but they only list beam sections that match a given span/load criteria to meet an acceptable deflection. I would prefer to size beams (residential applications only) for desired deflection values.
RE: Deflection calculator
Looks like it might do the trick - and the price is right!
The download site is down right now but I will keep trying.
