Pro/Engineer to Msc.Nastran for Windows
Does anyone export models from Pro/Engineer (any version) into Msc.Nastran for Windows (any version preferably 2001) and do an an FEA using Msc.Nastran for Windows. I am trying to do this but having some problems. I will feel better if I know that someone else has done this. Thanks in advance.
PS: I was not sure which forum would be more suitable so I posted this question in both Pro/E forum and Nastran forums.
RE: Pro/Engineer to Msc.Nastran for Windows
MSC N4W reads IGES, STEP, and parasolid.
"When everyone is thinking alike, no one is thinking very much." --Eckhard Schwarz (1930--2004)
http://www.EsoxRepublic.com
I'm not sure if you have a license that will allow this so bear with me...
Open your part, and go to Applications-->Mechanica, then select structure with the "FEM mode" button checked.
Some Pro/E licenses still allow FEM output, and if it does, make sure that the FEM mode check box is selected. If not, and you don't have Pro/Mech, it will tell you to contact your sales rep (booo).
Here you can create a boundary or solid mesh, apply mesh controls, loads and constraints, and "run" it. When you run it, you will have the option to output it to a PTC neutral FEM file, an ANSYS file (*.ANS) or a Nastran file (*.NAS, I believe).
Hope it helps
Mark
