Wildfire 2.0 Parasolid export
We use both Pro-E and SolidWorks and I have tried to export parasolid files to SW from Pro-E but the file always comes up invalid. What version is the parasolid? I just do a save copy and select the parasolid file type and name the file. Am I doing something wrong? Thanks in advance.
RE: Wildfire 2.0 Parasolid export
This is from a UG V18 Parasolid export file:
**PART2;
SCH=SCH_1302264_13006;
This is from Wildfire2 M020:
**PART2;
SCH=SCH_1000149_10004;
Wildfire is writing a Parasolid V10 file, which would be about 5-6 years old. For SolidWorks, I think any version since 98 or 99 should be able to read a V10 Parasolid file.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Any idea why Solidworks calls this as an invalid file then? I have tried this a number of times all with fail. Have you had luck with Pro-E parasolids in UG?
send me an e-mail with your Parasolid file and I will see if I can read it.
ben_loosli<at>irco.com
Ben Loosli
Ingersoll-Rand
Ben Loosli
Ingersoll-Rand
