Reinforced Masonry
Reinforced Masonry
Reinforced Masonry
Instead of using a steel column the architect would like to bear on a masonry grouted solid pier. I have the Concrete Masonry Handbook put out by PCA but it doesn't have any information on design procedures of a fully grouted cell. Can anyone direct me to a location that would help? Can it be calculated like a solid concrete column??
Thanks for the help.
RE: Reinforced Masonry
Yes, the calculations are very similar to a concrete column - the best document to use would be the ACI 530 where masonry design is very well outlined.  You might check on your applicable building code as some older codes also have specified methods of masonry design.
Use the ACI 530 or the Masonry Designer's Handbook.  Depnding on the region in which you are, it may not be typical to use ties for your vertical steel.  If you do not have ties, you cannot count the longitudinal steel as resisting axial forces.  This is easy to over look.  In Florida for instance we seldom have ties in masonry columns.
Check "The Masonry Institute of America", I believe they have a design manual.
Sorry, had a mental margarita and forgot the obious, go to NCMA (Nat'l Conc Masonry Assn) and check out the TEC Manual Section, see "Allowable Stress Design of Concrete Masonry Columns"
http://www.ncma.org
Best Tincan
