Slide for extreme temperatures
We are working in an automotive test equipment. First phase is complete, now we are at the second phase.
In 2nd stage we have to build a xyz table with servomotors or steper motors. The travel distance for the movement is 12inches in each axis, the accuracy is .05in. My problem: The XYZ has to be inside of a temperature chamber where tests will be perform, however temperature range is from
-40ºC to 85ºC. If the slides are aluminum and stainless steel material should I have problems with accuracy?
RE: Slide for extreme temperatures
You will also have to worry about your drive screw or belt since it's expansion will cause a more immediate effect.
I would have one guide rail fixed and let the other float. Also if you have a steel rail on a aluminum base you would need some compliance between them lenght ways. Maybe just tighten a couple of screws in middle and have screws on ends snug.
.050" sounds like plenty of slop till you start adding things up.
Good Luck, Barry1961
Barry1961
