Equations bug
Equations bug
Equations bug
Never rename a linear pattern feature dimension.
If you use a renamed dimension from a linear pattern feature in an equation you are in trouble. When editing the feature of a linear pattern, the names of the renamed dimension return to D1 automatically & the equation cannot be solved.
RE: Equations bug
Since when? I have often done this without problem.
What version & SP are you using.
Have you tried repairing SW.
from (the City of) Barrie, Ontario.
What happens if you get scared half to death twice?
RE: Equations bug
No but I called SolidWorks company and they told me that they knew that issue.
RE: Equations bug
The problem is for a component pattern only sorry.
Not feature pattern.
