Design Table losses link to properties in Solidworks 2005.
Hi, we just upgraded to 2005 this week. I am having an interesting problem with the design tables. We use design tables to control different configurations of parts. For example a bolt. We would use a design table to control the dimensions of the bolt but we also use it to control properties that show up in our BOM. In 2004 we could use a heading of $PRP@Weight and then "SW-Mass@@Default@MT230200.SLDASM" Would of given the correct weight of the part. These items would be linked. If the part changed size the weight was updated. Now, with 2005, I set it up the same way. It retrieves the current weight like it should. But the next time I open the design table the "SW-Mass@@Default@MT230200.SLDASM" is gone and the weight is displayed instead. The link is gone and if the part changes the weight stays the same. We do the same thing with the over all length, width, and thickness dimensions. Any suggestions?
RE: Design Table losses link to properties in Solidworks 2005.
Have you read or went through the "What's new" yet? Maybe they listed a change in there that affects this situtaion that you're seeing. Also check the "Release Notes" under "Help" another key source to read between versions.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Scott Baugh, CSWP
Instead of writing "SW-Mass@@Default@MT230200.SLDASM" in
the cell write: ="""SW-Mass@@Default@MT230200.SLDASM"""
Then the property stays in the design table.
I am using: =""""&"SW-Mass@@"&$A3&"@x.SLDASM"&"""" in the cell for easyly populating the other configurations.
The "x" in front of ".SLDASM" has no influence. Solidworks automatically equates the correct value for the document name.
HTH
