Flexure/Shear test data processing
Hello everyone,
I was wondering if anyone has a formula for deriving the flexural and shear strength of the composite from data obtained from a plain flexure/shear stress test using a 3 point flexure/shear test fixture (e.g. http://www.wyomingtestfixtures.com/Products/page37...)
M
RE: Flexure/Shear test data processing
I've been trying to do the opposite, that is why I mentioned about material properties in your thread on computer aided engineering.  I did download "the laminator" as you suggested, but as far as I can see it just uses classical lamination theory.  Using the micromechanics principles and Nastran 4W the results of a four point test could be predicted only to about ten percent with a sandwich panel of carbon, kevlar layup.  Some were better, but how do you know which one ahead of time?
Tom S.
tstanley,
I am trying to correlate computed values myself. I don't use Nastran so I'm out of luck from that standpoint, therefore I am relying on "The Laminator". Perhaps there is a better program (cheap) out there, but for now I am focusing on getting the process all together... I'll optimize it later...
I understand that engineers routinely predict flexural and shear strength from multipoint (3 minimum) flexural test results. I suspect there is some formula behind all this... I would like to get that information and I hope someone would help me out
I can live with a 10% variance as long as the computed values are below the actual ones!
Hi, assuming elastic regime,
Stress (flexure) = (0.75*L*P)/(b*d*d)
Stress (shear) = (0.75*P)/(b*d)
where P is the load of the 3-point test.
sgdon
To make sure I understand the values are for the test specimen and are:
L - length
b - width
d - thickness ... right?
Now what would the formula look like for a 4 point test?
Also, I have recently come accross a similar formula for the (flexure stress):
F = 3*P*L/2*b*d*d ... Any comments on this one?
Hi phoenix221
Apologise for the mistake here. Yes, you were right, the flexure stress factor should be 1.5.
For 4-pt test, you can similarly derive from 1st priciple, i.e. obtain moment from the triangular stress block and equate to the moment obtained from the free body diagram.
sgdon,
No problem... Just beginner's luck on my end
This is really testing the limits of my current understanding :-(...So the formula for a 4 point test would be written how?
F = ?
Ha..you are also trying to test my limits huh?!
For 4 pt and still assuming elastic, one can work out to be
Stress=Moment/Elastic modulus (For rectangular section, elastic modulus=bd^2/6)
Moment = (P/2)*l/3 (assume total load on the beam is P)
i.e. Stress=Pl/(b*d*d)
Having, i did come across people quoting 0.75Pl/(b*d*d). Now, this time round, you tell me why is that so?! I hope someone else may also be able to answer that..
sgdon
