DESIGN TABLES IN DRAWINGS
Is there a way to have the design table in a drawing have an anchor point. I made a design table to track our revisions and want to be able to snap to a anchor point on the drawing. I looked everywhere I could think of and found nothing about doing this. Does anyone have a workaround?
Is this an enhancement request for any of you out there?
Please let me know what I can do.
RE: DESIGN TABLES IN DRAWINGS
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Question#1: If I create a custom property called "rev1" and I assign that to the column in the rev table do I have to leave the colum description as "rev1" or can I change the description and still maintain the link to the column.
Question#2: If the custom property I defined is a configuration specific property will it look at all configurations of the part and populate the rev table accordingly?
I want to be able to have an automatically updateable rev table so that it makes less room for error. How does everyone else track revision changes in solidworks? I thought I would have a part file that has multiple configurations that designates each revision level. Not only would this make updating assemblies with the new revision easier but it would make updating drawings just as easy. The only way I have found to do this effortlessly is by creating a design table. But now the table looks out of place in the drawing. Does anyone have any tips on how to make design tables blend into the drawing without too much effort?
Any help that anyone can give would be greatly appreciated.
Jon
Can you tell me what the name is of the software you use?
PDMWorks or some other PDM system
Scott Baugh, CSWP
From what I understand is that they take the top request's and try to incorporate them into the next SP.
Let's band together to get this enhancement!!
