Swing Drive w/ ring & pinion
I need help – I am working on a hydraulic swing drive with ring and pinion. I am trying to determine what the final speed of the rotation will be.
The ring specs are:
12.5” pitch diameter
50 tooth
The pinion specs are:
3.5” pitch diamter
14 tooth
I am using a small Eaton gear motor to drive the hydraulic swing drive.
I have calculated the pump flow as follows
2450 (engine rpm) * 1.78 (pump disp) * .90 (Pvol eff.) * 1.116 (engine drive ration)/231 = 19 gpm
Then calculated the motor speed
231 * 19 gpm / 11 (motor disp) * .95 (Mvol eff) = 420 rpm
Then calculated the swing drive gearbox output speed
420 rpm / 25.78 (swing drive ratio) = 16.3 rpm
Now is where I am stuck – not sure how to calculate the final swing speed with consideration of the ring and pinion. I realize this may be an easy question for some, but I am not an engineer or anything.
Thanks.
The ring specs are:
50 tooth
3.5” pitch diamter
14 tooth
Thanks.
RE: Swing Drive w/ ring & pinion
4.564 times pi times 12.5 divided by 12
yields 14.936 sfm (surface feet per minute).
