Mulitple Exploded Views
Is there any way to create multiple exploded views for just one configuration? It seems that you can't, but thought I would ask. If not I'll submit an enhancement request.
Pete
Pete
RE: Mulitple Exploded Views
First create a config that you will be coping the exploded view to. Then activate the config that has the exploded view attached to it. Hit the + next to the config name to show the exploded view. Highlight the exploded view and "drag and drop" into the new config and select the + next to the config name to expand and see the copied exploded view.
hope this helps you in your process.
