Need a Part # for Parallel Cable Connector
I can't seem to locate who would make the "standard" 36-pin connectors. I'm not looking for the cable ends. What I need is a through hole right angle male connector. This would be the same connector that you would find on the printer end of a printer cable. I'm designing a product that would plug into the back of a printer.
I can't seem to find them at either Molex or AMP!!
George
