Autocad plotting
Autocad plotting
I'm running Autocad 2000...
I've run into some problem with shaded areas over printing some of my line work... is there a solution to this such as plotting sequence, where as the screen will plot first and then the line work...?
Thanks in advance...
RE: Autocad plotting
It should allow to you "Bring To Front" or "Send to Back"
