Shaft-hole fits, metal and plastic
I am looking for some tables on shaft-hole fits for a stainless dowel pin into a plastic part (ABS and Polypropylene). Does any one have this information, or a link? The machinery's handbook only talks about metal-metal fits.
specifically i an looking to press an M5 pin into an ABS disk, that will need to be removed periodically for maintenance.
RE: Shaft-hole fits, metal and plastic
To overcome this in plastic inlet manifolds on cars, they insert metal ferules or crush tubes, which bear the creep load.
pat pprimmer@acay.com.au
I don't have data, and can only advise that you enquire with all the major long established, reputable raw material suppliers like Bayer, Dupont, Ticona, BASF, GE, DSM, Basel, Atofina etc
I again refers you to Dupont "General Design Principles for DuPont Engineering Polymers" which can be found on the web. They have a whole chapter on the issue. I do not believe the press fit will disappear but it will decrease. Using the info on Dupont document you can calculate the residual press fit.
You might consider a splined pin and a splined hole, the teeth will take the torque.
