SW Explorer Problems
I work in SC have to use SW Explorer to copy my assys to my c: drive to do my designs.
The problem is SW Explores sees only one level in the assy structure and when I open it from my c: drive, deeper nested subasssemblies still refer to my network in NJ.
Is there any way to avoid that problem ?
Who do I talk to to solve it?
Thank you.
Andrzej
Thank you.
Andrzej
RE: SW Explorer Problems
Before copy, click the Search Rules button and check if the options are as you want (search subfolders should be selected).
Check also if you select Copy Children and if the folder to copy the children is intended folder.
