DIFFERENCE BETWEEN TOTAL DYNAMIC HEAD AND DIFFERENTIAL PRESSURE
P.D pump.
Total dynamic head = total suction lift + total discharge
 head  ( feet of liquid)
and the differential pressure is the same value but in psi
is Ok?
thank you
RE: DIFFERENCE BETWEEN TOTAL DYNAMIC HEAD AND DIFFERENTIAL PRESSURE
TDH= discharge (pressure/density +elevation+v^2/2)-
suction( (pressure/density +elevation+v^2/2)
Units are generally in feet or meters    but could be converted to  psi or Pascals
differential pressure  as stated is the difference in pressure  but could be stated in ft or meters.
