What is IEC 60298?
What is IEC 60298?
Can anyone tell me in general what is this standard is about? Its related to Medium voltage switchgear I believe.Does it also gives the degree of protection required for the switchgear e.g IP4xx
Thanks for the help
Thanks for the help
RE: What is IEC 60298?
Degree of protection (IP) is generally as per IEC-60529
A.C. metal-enclosed switchgear and controlgear for rated voltages above 1 kV and up to and including 52 kV
1. Scope
"This standard specifies requirements for factory-assembled metal-enclosed switchgear and control gear for alternating current of rated voltages above 1 kV and up to and including, 52 kV for indoor and outdoor installation, and for service frequencies up to and including 60HZ...This standard DOES NOT deal with components in metal enclosed switchgear and controlgear for which individual specifications exists."
See: www.iec.ch/cgi-bin/procgi.pl/www/iecwww.p?wwwlang=...
