OFFSET CURVES IN SKETCHER
How does one offset cuves in sketch mode?
TIA
TIA
RE: OFFSET CURVES IN SKETCHER
1) Create a sketch with the wanted profile and constrain it
2) Create an other sketch on the same plane as the first one. Use "project" to add in the profile from the first sketch (think it´s called exract in the earlier UG). Now you can use "offset exracted curves". Convert the original curves to reference so they don´t interfere in your future work.
I recommend that you use an user definied expression for the offset value, you will not get a feature in the MN. The offset is only editable through expression.
BTW, offsetting in sketcher is a rather hot topic with users lately & UGS is listening to suggestions for improvement.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
