Ventilation for Elevators Microprocessor Controls
Hi.
Wich are the requirements for air temperature and humidity to use microprocessor controls in elevators?.
Our elevators will work in a industrial plant, with high ambient temperature (up to 40°C or 104°F) and very high humidity.
Air conditioning will be the recommended choice, but we have a lot of troubles to give air conditioning to the machine rooms, that´s why we choose ventilation.
Is it possible to use microprocessors that can work under this conditions?.
Thank you.
Thank you.
RE: Ventilation for Elevators Microprocessor Controls
