reverse engineering
reverse engineering
Dear all,
I have point cloud data that has been produced using a laser scanner and I've been looking at Rhino to produce cross section curves through this data. I'll use these curves to create surfaces. In addition to this I see that FPS produce a plug-in, which produces surfaces directly from the point coud data, so I was interested if anyone has used this plug-in with any success or otherwise?
Many thanks,
Neil.
Many thanks,
Neil.
