pH measurement of oily water after gas/water separator
Hello All:
I'm looking for a relatively maintenance-free and robust solution for accurate measurement of pH for use after a gas/water separator in an oily water environment. Max temperatures will be around 120F with pressures possibly reaching nearly 500 psi.
Doing this type of thing in a refinery-type environment has been tried many times--but has anyone actually had any long term success? Possibly through the use of on-line cleaning systems?
Any suggestions for probe manufacturers?
Thanks in advance for any help.
RE: pH measurement of oily water after gas/water separator
m777182
