Infrared communication in space over 15 foot distance
I am designing a space based antenna array and would like to talk from one part of the antenna to the other part using simple infrared transmitters and receivers, similar to your remote control on the television, i.e. something cheap for our high quantity. The receivers will often be hit with direct sunlight. Tranceiver units would be best so there is two way communication. Is there any way to use IR or other filtered light to send simple digital codes for a distant of 10 to 15 feet in space (MEO orbit)? Our present discussion is to use fiber optic cables to distribute commands, but it would be much simpler, cheaper and better for testability if light was used.
Any hardware suggestions?
kch
kch
RE: Infrared communication in space over 15 foot distance
Jack M. Kleinfeld, P.E. Kleinfeld Technical Services, Inc.
Infrared Thermography, Finite Element Analysis, Process Engineering
www.KleinfeldTechnical.com
<nbucska@pcperipherals DOT com> subj: eng-tips
